I'm wondering how many folks are running pump gas or if most turbo owners
end up running race gas or 50/50 or Av gas ?
thanks
let it snow
thanks
let it snow
I have for a few days here and there or when I run out of race or AV fuel. I alway end up spending the extra 20 dollars a tank to turn the boost up though
7# is kinda the sweet spot IMO for kick *** power and not slinging huge clutching to handle the big power, also, still fairly linear power so easy to ride. once you start getting up 9+ psi its so hard to ride them as they get clutch lag due to fat weights and steep helixes. also, they come on so damn hard its really rough to hold on. they just wear you out as your on and off so much to keep under control. If your riding super deep pow and more open terrain its fun, but if your just bombing around in the woods its really overkill IMOthats good to hear what elevation ?
i've talked to a about few riders about fuel and getting consistent
fuel quality and tunning to your fuel and stick with that fuel can be key
i wonder how the performance characteristics change as the boost
is turned up
is lag more likely at higher boost ?
does there seem to be a boost # sweet spot for tree riding
(i guess that might be kit specific)
obviously the power is affected by boost
let it snow
Never even considered running pump gas. Always avgas or better. I don't know why this topic keeps coming up.
Probably because some clown turbo company markets a "pump gas turbo." Ya, ok. They also are laughing all the way the bank knowing full well that you will spend at minimum, 50% of the turbo cost on repairs at their shop. Dam, I'm opinionated today.
Do a quick search on compression ratios, boost PSI and altitude relationship. You will have a heart attack when you find out how high of octane is required.
