I got a DET code about 10 miles into a ride the other weekend, had to limp it back home for the day to check it out. I started pulling it apart and noticed the PTO side spark plug had an odd grayish looking substance on it so I figured it maybe it wasn't getting enough fuel. Mag side spark plug looked completely normal so I thought it was most likely the injector on the PTO side. Pulled off the fuel rail and injectors, cleaned them (PTO side had looked a little dirty, then again so did the mag side), and then put it back together. When I started it up it seemed to only be running on one cylinder so so I checked compression on both cylinders with mag side being about 130 and PTO side was 90. So I started to dig deeper..
When I got the head off I noticed some "not insignificant" scarring on the PTO side cylinder and piston. Found some metal shavings on that side as well.. Previously when I've seen this it's been a cracked/broken ring, but they both seemed to be fully intact on the piston still. I did notice that the piston (both the mag and PTO side) had a little bit of side to side movement in the cylinder which shouldn't be there.
The sled is bone stock, just bought it this year with 300 miles on it. Put about 500 more of my own miles on it, never let it go above 140F and then this happened.
I have a couple questions here (first time working on a Polaris so bear with me):
1. What could have caused this scarring and metal shavings in the cylinder? Is the piston on some sort of bearing at the end of the crank shaft? Maybe that's shot and a piece of metal came off of that? Blocked oil injector? Not getting enough fuel? I'm going to fix this and don't want this happening again after a couple rides..
2. What's the best course of action for a fix? I'm no machinist, but i'm not sure the scarred cylinder could be rebored to stock (maybe i'm wrong). I have looked into a couple different 660 big bore kits and I have been wanting to get the Carl's Cycle setup, I just haven't been able convince myself it's worth the money - now I HAVE to dump some money into the sled so might as well get what I want, right?
The thing ran like a DREAM all season with no issues, I was just getting ready to sell it to upgrade to an Axys 800 ? (at least I didn't sell it to someone and have it blow up a week later, good karma coming my way? hopefully?)
