R
I need some advice please,
I am on my 3rd stator in 2 years-
First stator- one of the charge coils goes (factory AC stator)- Ohm test confirmed
Second Stator- Lighting Coil melts soldier off yellow wire at stator (repeatedly)
(check all wires – figure it was grounding out)
(purchased 3rd stator after peak voltage test showed lighting coil was putting out 20-55 volts (assumed this was causing the melted soldier wire)
Third Stator- (I installed a fuse on each of the yellow lighting coil wires before the CCU)
Runs fine with a 15 amp fuse for a few hours- fuse blows installed a 25 amp and works well.
Other yellow wire fuse now blows 15 amp- Installed 25 amp fuse runs for 2 hours
Sled starts running poorly
Sled dies
Crack open stator housing- Charge coil brown/white wire melted off
Fuel pump coil orange soldier melted off
I first thought it maybe the CCU (voltage regulator contained within?) however from what I read. The Only CCU/ECU interaction is the APV motor signals? The fuel pump and charge coil # 2 should not have anything to do with the CCU?
Checked the ground wire and it is good.
IDEAS????
Also- Ohm tests on current stator-
Charge coil- #1 9.1 ohm spec is 7.2-10.8
Charge coil- #2 8.8 ohm spec is 7.2-10.8
Lighting coil .3 ohm spec is .08 -.12 (out of spec but functioning)
Injection coil 15.2 ohm spec is15.2-22.8
Fuel Pump coil 1.5 ohm spec is 1.52-2.28
![Rain :rain: :rain:](/forum/images/smilies/new2010/rain.gif)
Sled dies
IDEAS????
