New turbo question
hontri
30
Got my new turbo installed. She is a beauty! My kit came with what appears to be SSI clutch weights with the magnets. The paper that comes with the weights says the small magnets are 1.5 grams and the large weight are 2.5 grams. The magnets i received come in 4 sizes. 3 small,3 medium,6 large and 3 extra large. Anyone have an idea what weighs what. Also where would i weight them? Tip heavy,mid heavy or heel heavy? I'll be running 7# at 5-7 thousand feet.Pink primary,black green secondary 46-48 helix. New to turbos any info appreciated. Thanks.
562xp
118
47
I have three different sized magnets in the kit. Small medium and large. 1 gram, 1.5 gram and 2.5 gram. I set mine at 3 large then a small in the heel and a medium in the center. Will try it tomorrow to see how it works. :face-icon-small-hap Also riding similar elevation.
AKFULLTHROTTLE
1,987
1,146
Alaska
Best thing to do is a get a food scale and weigh them yourself. I tend to set them even and has worked fairly good.
With those weights I recommend purchasing SSI Lime Green 125/310 primary spring as your engagement will be crazy with that pink spring. Or at least the almond/red... Something with a lower engagement.
Also a black/white or black/silver secondary spring will help reduce weight needed in the primary.
hontri
30
Thanks for the info 562xp. AKFULLTHROTTLE could you clarify something for me. The springs i mentioned were supplied in the Silber kit. The pink spring on the polaris spring chart is 112-200. The almond red is 165-310. Would the pink not engage lower than the almond red? Or is the supplied pink(from Silber) different than the polaris pink. Good idea on the scale. I think i will get one and take the guess work out! Just in case this is on a 14 pro.
AKFULLTHROTTLE
1,987
1,146
Alaska
Is it a straight pink? I do not know of another pink primary spring.
The pink they used to send out was a 180/320. Venom spring.
hontri
30
Yup straight pink. The helix is marked as from Venom so maybe the pink spring is also. Thanks for the info. 180 -310 would be higher engagement for sure.thanks
AKFULLTHROTTLE
1,987
1,146
Alaska
Ya combined with the different engagement of the SSI weights you may see 5k which is no Bueno!
