go high fast Well-known member Lifetime Membership Premium Member May 7, 2008 1,544 466 83 Missoula MT Jan 16, 2016 #1 Measuring crank run out question– Can 800 VES motor crank run out be the measured with motor in Sled or does it have to come out? What tools do I need for this measurement? Thank you guys.
sled_guy Well-known member Premium Member Jul 5, 2001 3,566 843 113 Riverton, Utah Jan 18, 2016 #2 It can be measured in the sled. You will need a good magnetic base and a dial indicator. Pull the plugs out of the motor, polish the crank end with some scotch brite, mount the dial indicator and slowly pull the motor over. sled_guy
go high fast Well-known member Lifetime Membership Premium Member May 7, 2008 1,544 466 83 Missoula MT Jan 18, 2016 #3 Thanks. You rule!
