MBMS/SHOP 2010 HCR Boondocker Pump Gas Turbo Build
4.00 star(s)
L
little_orange_cat
Apr 7, 2008
361
41
lynden
www.myspace.com
Hey everyone it's Michael here. This is a new 2010 HCR and we are putting on a Boondocker Pump Gas Turbo Kit. It's Woody's sled from Mt. Baker Moto-Sports. Let's get started.
1. take off skis, hood, bumper, side panels, intake, and exhaust
2. shocks to Holz Racing for revalve
3. install boondocker air box, relocate ecu
4. install boondocker box harness
ok now we have to go put the turbo oil tank and turbo assembly together.
104_0115.jpg 104_0114.jpg 104_0137.jpg 104_0139.jpg 104_0140.jpg 104_0109.jpg
L
little_orange_cat
Apr 7, 2008
361
41
lynden
www.myspace.com
assembling the turbo and oil tank assembly
now we had to put oil tank and the turbo assembly together. we also installed a vent from Skid Performance where the original exhaust exits.
ok now we have to go hack up the tunnel for the muffler system. we will be back.
P
PIKER
202
22
18
Lethbridge Alberta
I am guessing that the boondocker air box has tapped holes on either side for secondary injectors, can you add secondary injectors/fuel rail and make it work with the intake hole set in between the injector holes?
Thanks,
Piker
Woody67
1,437
682
Bellingham, WA
Thanks,
Piker
I believe this air box is for pump gas only but not sure. I think the other holes are used for part of the ADA system and boost reference but not 100% positive because as many of you know we don't have all the parts for the kit EBC/ADA
Aug 20, 2008
372
23
18
49
North Idaho
That exhaust hole vent is exactly what I have been looking for, Where did you get it from? skidperformance.com is no longer there. I am very interested in getting one of those, any help would be greatly appreciated:beer;
Woody67
1,437
682
Bellingham, WA
I got it from OVS/Pure Logic. They use them in their kits I am sure you can buy one from them.
L
little_orange_cat
Apr 7, 2008
361
41
lynden
www.myspace.com
the new muffler system
ok so that was an adventure. We put in the 3" hole and then the 2 1/4" through the tunnel. Those are just pilot holes and then you have to trim and hack away to get clearance to get the muffler installed. And then for rub clearance once it is firmly mounted. You need hole saw extensions and long grinding tools to be able to access the exit hole.
104_0156.jpg 104_0157.jpg 104_0158.jpg 104_0159.jpg 104_0160.jpg 104_0170.jpg 104_0171.jpg
L
little_orange_cat
Apr 7, 2008
361
41
lynden
www.myspace.com
fuel system modifications
the fuel system was a walk in the park after the muffler install. We also put on a 2009 M8 head. The compression ratio on the 2010 is too high for the PG turbo set up. Tomorrow we will fit and weld the main pipe and stinger set up. And eat turkey of course.
R
rcaustin
238
70
Calgary, Alberta
Do you know the website or phone number or something? I tired to get on ogdenvalleysports.com but it says the domain has expired... not to sure what that is about.... I am also interested in the exhaust hole vent.
K
Klimbing Kitty
Woody67
1,437
682
Bellingham, WA
Happy Turkey day boys! Kieth, Michael, and Woody it is looking Sweet. Can't wait until we can take all our T-sleds to the hill together:D
Happy Thanksgiving to you Robert. Yes it should be good-the ride around my yard when we got yours done was not really enough was it?
Aug 20, 2008
372
23
18
49
North Idaho
That link does not do any good, The domain name has expired . . . Skid Performance does not work either. I would like to order one of those vents, does anyone recall who actually manufactures them? Maybe we can go to the source to order them.
Interesting, it works fine for me. Is thers a specific item you're looking for? I can print screen shots and send them to you via PDF if you'd like.
The website says they are having a limited time sale on pump gas kits. $4000
