Koso water temp install help- 08 SP 600 MOD
F
frostbeitz
New member
Dec 1, 2008
39
39
Koso egt's - install help- 08 SP 600 MOD
about how far are you guys running the egts for the speedwerx twin?
08 -sp 600
4-6 inches?
I just got the koso dual egt and water temp,
The tabs that are welded on the pipes for the springs are not allowing me to get closer than 6" from the outside of the cylinder, I don't really want to go closer, I'd like the clamp to be strait and a sucure fit.
If you do know how far you mounted and you comment, could you also mention some temps you are seeing.
You can email me if that would be easier, frostbeitz@msn.com
Thanks!
m8magicandmystery
7,786
3,724
Yukon
on the 800s they mount in the hose down by the recoil../exchanger..1 inch hose...is the 600 the same..??
