For information, how many miles we can get on the stock crankshaft?
300 if not summerized.
If you grenade a belt you're crank is bent.
Lube that bottom end.
Iceman56...could be... have you checked for crankshaft run-out with a dial indicator??
SMF makes a good point.
To clarify (if you don't already know this)
"Grenaded" means a catastrophic failure... You are on a hard pull and your belt snaps violently with a heavy load....pulling threads or getting a flat spot in the belt is not typically called "grenading"
Does going over the bars and landing in front of the sled face up because belt suddenly "grenaded" count as a hard enough pull and violent enough snap?
This is how they all go with a turbo unless you catch a cord pulled and change it before it goes.
Don't even know what crank shaft run out is or how to check it but sled grenaded belts throughout the year and ran like a champ the whole time
Indydan's post.
The belt wont bend your crank, BS
