Second year with this unit. love it! But damn it's a tough nut to pull over when cold. Did any of these units come with compression release? A spit of starting fluid is the easiest way to get it going.
The Decompression hole is not the problem. I have all of mine plugged off to gain HP. There is a reason SLP lists plugging them off in their services available section. The 02 motor is the only one to not have them. The reason it is hard to pull over when cold is the oil film. Park it inside! It will pull over great.
I've read in several posts here that applying full choke for a few seconds on shut down will thin the residual oil with fuel. Doesn't make sense to me as doesn't the choke just restrict airflow? Could be it's un-combusted fuel doing the thinning? Can't say that it's helped consistently.
Today I sprained my thumb and seem to have pulled my left tricep from a cold start :face-icon-small-sho
The choke on the MIKUNI RACK Carbs has a brass piston, which when raised up allows additional fuel to flow into the engine.So the choke on an edge increases gas flow, doesn't just restrict airflow? That should be helping my cold starts. Something is up as I'm 6'3 200+ and was a piano/safe/large appliance mover not so long ago. If It's hard for me, something is going to break :face-icon-small-sho As mentioned, mine's an '02 and it's ok to pull cold, a little stiff. It's when I go to restart 1 to 1 1/2 hours after a days riding, when I want to unload. Thats when it's really hard. It's easy enough If I shut down for 15 minutes. Top end is pretty new still, maybe 250 miles.
Any theories on this?
Not a good idea to use starting fluid to start a 2 stroke engine. May result in cold seize.
Of course starting fluid aids in starting your sled, its a highly combustible fluid. But it should not be needed. Get your carbs clean and adjusted properly for your altitude, good plugs, and it should start within 4 or 5 pulls in any conditions. Unless mine is flooded, its never more than 3 pulls. I suppose if you have bad shoulders or something, you may want to look into e-start, but if you're a healthy individual they really are not that bad to get going if properly setup.
They tend to rev up pretty high when started on this stuff, high rpm on a cold motor isn't ideal (not as bad as high rev & high load though).
The ether is also a solvent for the 2 stroke oil, so it could (and you'd probably have to be using alot of ether) wash the cylinders clean of any lubrication, damaging rings/pistons/cylinders.
