Carbon fiber tunnel wrap
J
Aug 19, 2013
92
6
8
NE Nebraska
Ok I am about to wrap my tunnel with carbon fiber wrap. My question is , and I'm hoping someone has some insight, drill out rivets or go over them and cut them out. I'd like to do the whole tunnel.
F
fast8seccamaro
394
157
Thorsby Alberta
Clean good, go over rivets and use a heat gun and bank card and press down around all rivets! Might have to touch it up every once in a while but mines been on for 2 years and no problems, looks good!
predator800
349
96
Saskatoon, SK
Mine was the 3m stuff. Usually anyone who does signs or wraps can get it for you. Just got mine at the local vinyl supply shop.
F_ast
973
361
Ontario
I used a product called Orajet. Much better quality and a lot more realistic look. It actually has a grain.
I removed my rear bumper and went behind it. I also found using pressing down on the heated wrap over the rivet with your thumb for a 5 count worked best to get the best coverage over it.
Sled208
434
205
Are you sure it's not called oracal?
F_ast
973
361
Ontario
Could be Oracal... but pretty sure it is called Orajet. I will go take a pic when I get home
But I really would suggest going over the rivets and for 2 reasons. First, it is much much less work then drilling them all out and reinstalling. The second, if you ever damage the wrap, you can just peel and relay. If you have the wrap under the rivets, you are stuck having to use a razor blade to cut close to all the rivets; then what... drive all the rivets again, or just go over them???
It is a clean look going over the rivets but takes a little more patients
Phizzer
1,219
422
83
39
Ketchikan, AK
Most of the sleds I've seen have just wrapped over all the rivets as well. When I wrapped mine, I had the whole sled apart and bare tunnel, which is why I chose to wrap then rivet. Gives it a different look having the river exposed. The stuff is actually easy to work with. Once you start using it a bit, you get a feel for the way the material acts under heat. Good luck!
kidwoo
2,630
1,875
Hows the durability of that carbon grained stuff?
I put some 3m 1080 on my tunnel this year and it's getting a little torn up from boots or pant zippers or something.
F_ast
973
361
Ontario
Mine has been awesome. I put 700miles on the sled this year and it doesn't have a mark. few boot scuffs, but I think its mainly rubber.
And yes, it does seem to hold less ice and snow than raw
