Looking for opinions on Axys cans. I've got a 17 coming leaning towards SLP I want a mild not wild sounding can. Thoughts? Or links.
I run the SLP, sound is good - throaty but not loud. Fitment could be better, the top of it is very close to the top of the panel on that side and I have a small blister from it on that panel (small than a dime). Tried to mount it differently but could not gain any clearance.
Thank you for asking about a "mild" sound. The only two I have heard that have acceptable levels of sound are the Diamond S Quiet, and SLP. The Diamond S definitely gets louder with miles-- I wish they built it where you could repack it easily.
"Quiet Recreation" is the latest mantra from the non-motorized contingent. It is also the hardest to defend against because of its subjective nature.
I run the Diamond S Quiet can. I ran it with a stock pipe, an SSI mod pipe and now an SLP pipe. It is quiet and it is light at 3.5 lbs. No sound change either with over 800 miles with the three different pipes. As mentioned above, it does not have packing, it uses baffles to control sound and back pressure. The SLP can is good too but it is so close to the side panel that it can melt the panel. I have seen that happen on several sleds that have that can on them. Given the price of a side panel, it makes the Diamond S a better value. With the SLP pipe and the Diamond S Quiet can, I have dropped the weight on my sled by close to 20 lbs. That is cheap for weight removal plus the SLP pipe makes more power and torque. It is a great investment to make a good sled even better.
Did you have any detonation issues with this pipe/can combo?
What altitude do you typically ride at?
X3 and how was the fit?Did you have any detonation issues with this pipe/can combo?
