850 walk through with Polaris engineer
RMK-King
Super-Moderator
Dec 25, 2007
1,928
1,374
North Dakota
Louie from Powermods made a nice little video showing the 850 at the snow show, thought some of you might be interested in seeing it.
https://youtu.be/5BggbBdvuF0
<iframe width="560" height="315" src="https://www.youtube.com/embed/5BggbBdvuF0" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Teth-Air
4,571
2,800
Calgary AB/Nelson BC
www.specified.ca
I wonder how many 800's had problem with varying fuel pressures? Must have been some kind of an issue if now there are pressure and temperature sensors. Maybe explained some of the low RPM issues of the past?
BeartoothBaron
1,250
1,329
Roberts, MT
Man, guess I've been hallucinating, because I could have sworn that the Fuji 440 I've been tinkering on had single-ring pistons. But it was built in 1980, and the Doo 850 has only been available to copy for a couple years, so apparently that's not possible...
FriscoProx
755
191
Seemed strange he said the 850 was clutched for same rpm's as 800, 8250-8300.
off trail mike
318
129
New Brunswick, Canada
Seemed strange he said the 850 was clutched for same as 800, 8250-8300.
Same rev's but guaranteed different clutch weight with bigger HP.
Still interesting on same revs...I was watching BMP do pulls on the 840 with max torque at 8000/8050 RPM and HP at 8100 with a few different pipe heat numbers. Almost seems they are clutching on the high side, but I likely longer pulls and hotter pipe would definitely move the rev's higher
https://www.youtube.com/watch?v=E3hLkQ-Ezks
Time will tell.
OTM
pinko
693
123
Wembley, AB
Hmm I have one with estart coming which I will be removing. Wonder if I need that block off plate?
Sent from my SM-G960W using Tapatalk
