850 patriot clutch weights (ramps)
J
Feb 27, 2018
16
4
3
Shopping for ajustable ramps for my snow check and was interested by the BMP Goldstar’s
Does somebody now if there will be a specific product for the 850s or the 58 to 81 grams will be ok ?
http://bikemanperformance.com/bmp-goldstar-adjustable-arctic-cat-clutch-weights.html
J
Feb 27, 2018
16
4
3
I had the goldstars in my 16 SKS. The bushings they use in them are junk and were worn out in about 250 miles. I used MDS clutching with their weights after that and I never had anymore issues.
Good to know! Tanks!!
Have you had any feedback on the SLP’s?
( https://www.startinglineproducts.com/catalog.cfm?pageID=detail&catalogID=3&catID=17&productID=3281 )
But they only go to 72.8 grams. I think this will not be sufficient for low elevation on the 850. Hearing + 4 grams compared to the 800 for same applications.
BILTIT
1,682
482
83
45
Lloydminster, SK
I run the slp magnums in my 11 rmk 800 at 2200'. I have some room left for weight. I am clutched and powered similar to an 850.
SLP Magnum force Link. CLICK HERE
Sent from my SM-G925W8 using Tapatalk
revrider07
2,034
1,001
ND
Im going to ride mine stock first year then go from there when there is clutch kit offered will make that decision with balancing the Clutches. My 13 was and is a very impressive sled in stock form. Tried many pipe and can combos on a 14 like mine but was not impressed with any aftermarket stuff other than clutching. I dont ride low elevation so it will be clutched at 8 to 10.
Wheel House Motorsports
29,933
5,971
SW MT
Honestly, the OEM clutching has always been pretty dang good. Talk to dealer, get elevation chart, run the OEM weights. So little experience at this point aftermarket is sort of using educated guesses on what they need. Factory is really the only one with legit real world calibration time.
R
Ratchit
ACCOUNT CLOSED
Mar 18, 2013
128
76
here
Ran those gold stars and the profile is to flat. You add tons of weight and go no where.
Not for us fast trail and racers that’s for sure
Dalton qap weights are almost identical with 10 series profile with set screw style . That’s the best for easy change on trail we’re u don’t even have to take belt off
J
Feb 27, 2018
16
4
3
Sent a email to SLP
Fast and compete response!
Hello,
We are working on a special Magnum Force weight for the 850. It does have a power curve that is different than other engines so it needed a special one.
Being a new model the products take a little time to get ready but we should have things well in line near riding season.
