I run a fleet maintenance shop at a ski resort. We have about 40 Polaris sleds (all fans) and have been running Polaris fans since about 1996, so for over 10 years now. I have two major problems that I can't sort out.
1. Burn downs. Our engines have gotten progressively more and more unreliable to the point that we're at now, which is that motors are lasting as little as 5 minutes! With old 488 fans, we used to see 8-10k miles from a new OR rebuilt 488 fan, and we ran Wiseco forged pistons in the rebuilds. In the 550's that dropped to 5-7k miles, and when the Nicasil cylinder came out, engine life dropped to less than 4k miles, so we started trying different things.
We've run Wiseco's, SPI's, and Polaris. None seem to work or last any better than any others. On the Wiseco's we set our piston to wall clearance at .005" and with the SPI's we use .003".
We've tried various brands and types of oils and none seems to be any better or worse than another. Our fuel is from the same vendor that we've used for the last 11 years, and is the same brand and type. None of the burn downs are detonation related. They're all seizures or broken skirts.
2. Jetting. We've been running 220 mains in the 550 for YEARS...since they introduced that downgraded motor (from the old 488 fan) and that jetting has been just right "forever" for the most part, for our elevation (7-9k') and temps. *Some* machines preffered 210 mains. Anyway, all of the sudden, this year, 220's aren't enough and machines are running lean. My mechanics aren't that great at reading wash and plugs, so yesterday I took it upon myself to dive into a freshly built motor and see what jetting it would like best. I started with 240's to be safe. WOT, for over a minute, cut it off clean and pulled plugs. The color change on the ground electrode was basically at the weld, and there was essentially NO piston wash. I went up to 260's and ran the same test. Results? Same. (!) WTF is going on here?? Floats are set to spec, new fuel filter and fuel lines, etc. I'm baffled. Also, I noticed that UNLIKE the old Gen II chassis sleds w/the 550's, these Edge machines see a HUGE...HUGE change to A/F ratio when run with and without the vent tubes hooked to the air boxes. (?)
Any insight as to what I (we) are missing would be greatly appreciated.
Additional Question: I have been a member on this forum for YEARS, but haven't been active for several years as my personal snowmobiling/modding has taken a back seat to other life endeavors. When I went to log on today, it seems that my membership/registration is gone. (?) Did the board go down and loose all data or something? What happened to ALL the posts I made, years ago?
-Tom
-Tom
