Hi guys
I'm heading to the Big Horns in Wyoming this Winter for the first time. I've done some reading on what I need to do to get the clutching all setup for my sled. But I have found some information that varies so I was hoping someone that has a similar setup to me could explain what they have done.
Sled specs. Completely stock 09 Crossfire 8, with a 2.25" Powerclaw track.
First question is for the Big Horns of Wyoming, what elevation should I be clutching to: 6000-9000 ft, or 9000+.
I will be running the 36 degree helix as per the label in my secondary, but the questions I have are about the primary.
According the label on the sled I should be running 68.0g for 9000+ and 73.0g for 6000-9000. When I looked the parts up on Arctic Cats parts fiche I came up with different numbers (I am assuming the parts fiche is wrong and go with the label?). The arctic Cat parts fiches says 75g for 6000-9000 which I ordered and have at my house. I am pretty sure they are wrong and I now have a set of 75g weights for sale.
So could someone help me out with which cam arm I should be running?
Another option I was considering was getting some adjustable cam arms. I've never really played with clutching before so this is all new to me. Likely looking at getting Cutlers, or does anyone recommend something different? My question here is what weight range should I be looking at? They offer 65-75, or 70-80. If I need 68 to run 9000+ and then at home I would need 77, I am just on either side of the ranges you can buy. I'm thinking probably the 70-80 would be most versatile for me.
If I did go with the Cutlers, how difficult is it to get them set right. I only have 5 days out west, and want to mess as little as possible with the weights while I am there. I read about end loading (which has to be done before install) vs. regular loading which can be done with them in the sled. If anyone has run this setup and has some tips I'd really appreciate the info.
Hoping someone can get me straightened out here so that when I get to Wyoming I'm not stuck on the side of the hill messing with weights.
Thanks all.
Jason
Thanks all.
Jason
