U
2004 Arctic Cat 600efi Mountain Cat 151"x2" camoplast track with suspension drop brackets. Suspension was upgraded from a 144 to a 151x2 and fits real nice under the stock tunnel. Has factory drop & roll chaincase. The original 600 efi motor was used for another project. A 2000ZR 600 efi motor was installed in this chassis three years ago. The motor has 2573 original miles, the chassis has about 200 less original miles. The 2000 motor came out of a sled I parted out because it was a short track. It was a direct bolt in with all arctic parts, looks factory. The only difference between a 2000 600 and a 2004 600 is exhaust valves and about 6 HP. All 2000 electronics, fuel systems and exhaust were a direct bolt in also.
Sled is 2nd owner but was bought new by a friend so I have history since new, Always has been stored inside and hauled in an enclosed trailer or sled deck, very good condition with no current or past damage except for a hood scratch. Has never been damaged or wrecked. Motor is stock, has never been overheated or has ever been apart. Primary clutch has just been freshened up with new pins and bushings. Sled is ready to ride. This sled has had a very easy life, mostly ridden by women. Everything works as it should. Has Exhaust can, 2" handle bar riser, ice scrapers, tether, good hyfax, a factory temp gauge, Simmons Flex skis and a kingcat 11/4" drive shaft. Arctic black & green color combo. Very clean, nice and reliable pull & go sled. If interested or want more pix pm $2300 cash without dash bag in pix.
Pix on CL add
http://kalispell.craigslist.org/rvs/4248705298.html
Thanks
Pix on CL add
Thanks
