Rear suspension sag
Team X-treme
New member
58
4
8
The rear suspensions sags on its own weight pretty bad. Does a stiffer spring help or are my shocks bad? It is on a 2007 RMK 600, no Walker Evans just the standard shocks. Thanks.
MARV1
8,980
1,593
Kotlik, AK
^^Agreed, this is something Polaris needs to address, install the .405's in at the factory, way better all-around performance with these on.
R
Ron
ACCOUNT CLOSED
Dec 4, 2006
2,711
473
83
Boise
Polaris designs some sag into the suspension. The correct way to determine if you need stiffer springs is to measure sag with the rider on the sled using the measurement from your owners manual for your model sled.
Springs not shocks control sag!
O
Ollie
ACCOUNT CLOSED
Mar 16, 2004
5,396
498
83
Colorado
the correct way to measure sag is..................
put the sled on a flat surface.
Lift the back end up and measure from the end of the tunnel to the ground.
Get on the sled, hop up and down 3 times then sit on the sled.
Measure the distance (with you sitting on it) from the end of the tunnel to the ground.
You should be around 5" of sag.
I had to install the factory large spring on mine to get this amount of sag.
The stock factory springs gave me about 11" of sag.
T
Oct 10, 2001
1,310
142
Spokane WA
I bought my "fat boy" springs from the Polaris dealer when I bought my sled. Is there aftermarket companies that also make "fat boy" springs out there too? I'm wondering if you could call an after market company, tell them what sled you are riding and your weight. That way they could sell you the right spring rate spring.
M
magician
New member
Jul 9, 2001
116
So. East, Idaho
suspension springs
:) I have a 06 600 rmk 151 and I weigh about 230 all suited up. I see the stock springs are .359 and they show a .375 in the parts as an optional part. Do they make some .405's? Is this what to go to to stiffen it up? I think going to a longer track makes the problem worse.:):):)
O
Ollie
ACCOUNT CLOSED
Mar 16, 2004
5,396
498
83
Colorado
yep, the bigger the spring the less sag you will have.
You do have to be carful though. Get too stiff a spring and you start bending rails.
M
magician
New member
Jul 9, 2001
116
So. East, Idaho
sag......
So if the sag is close I should probably just go with the .375's. I'll do a little more measureing with the close rider weight(backpack, shovel, etc.) and then have an idea how stiff to go....Maybe the .375's will be enough......
H
Jan 9, 2003
688
53
Sparks, Nevada
I would strongly reccomend going with the .405. We tried using both the .375 and .405 and I wouldnt waist my time with the .375 they are not enough. I am 200# all ready to ride. Thats just my opinion. I have been riding them on my sleds since 04 and I have never bent a rail or had a problem. On my 05 IQ race chassis i run the rail brace to keep it strong.
M
Jan 24, 2008
92
2
8
37
cannon falls mn
Im also 230 all suited well maybe 250 lol. I ride an 06 600 ho and it sags bad. My factory is .347 with an 80 degree bend. My book is telling me the bigger springs are .359 80*????. Thats not much more can i go with a wider spring per say .375 or .405 and could i maybe go to a 90*instead of 80*
Kale
33
Just ordered the .405 77 degree from Polaris' online site for my 07 Dragon RMK. The .405's were the only ones available, so if you're thinking of buying them, I'd do it before they're not available like the other springs.
Kale
