Upgrade to Premium
Ski-Doo: ZX Sleds 99-2005, all models in the ZX chassis
Reply
  #1
Old 01-08-2011, 11:16 PM
doozack doozack is offline
Currently: Not set.
Basic Member
doozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond reputedoozack has a reputation beyond repute
Default 2002 mxz no spark?
My buddy has a mxz with no spark, he replaced the stator and still no spark. We had the coil tested and it is good. Any ideas? How do you disconnect the killswitch? Test the mpem? Any help would be great, thanks.
Rate this post: Yes | No
  #2
Old 01-10-2011, 07:05 PM
sgtX sgtX is offline
Currently: Not set.
Basic Member
sgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond reputesgtX has a reputation beyond repute
Default
trace wires from the kill switch, and ohm it out and should either be open or measure like .1 ohm, when he replaced the stator did he replace the trigger sensor?
The Following User Says Thank You to sgtX For This Useful Post:
doozack (01-11-2011)
  #3
Old 01-10-2011, 07:48 PM
hymark860 hymark860 is offline
Currently: Not set.
Basic Member
hymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond reputehymark860 has a reputation beyond repute
Default
check ur plugins on MPEM not sure about 02. In 01 there were two plugs that would interchange and cause no spark.
The Following User Says Thank You to hymark860 For This Useful Post:
  #4
Old 01-11-2011, 07:48 PM
Currently: Not set.
Basic Member
Default
Thanks for the info guys, I was looking at his sled in MN and we tested the triggers and they ohmed out good. Pretty sure there were'nt any interchangable plugs on the mpem. I came back to Salt Lake and heard he got fed up and brought it to the dealer. I felt bad I could'nt fix it, probably going to cost alot at the dealer. Atleast we learned alot. Wrenching to ride, got to love it.
  #5
Old 01-30-2011, 09:33 AM
brianstrange brianstrange is offline
Currently: Not set.
Basic Member
brianstrange is an unknown quantity at this point
Default
Quote:
Hi, new member here. I found this forum searching for the same issue. What did the dealer say?
I have a 2002 Grand Touring RER and electric start. The sled won't spark without a battery (it's currently dead) Even with the battery disconnected, no spark. I replaced my stator, but that wasn't the problem. I'd really be interested in what caused your problem
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — 2002 700rmk spark on only one side Thread Starter — summersucks Forum — Polaris: EDGE Replies — 1 Last Post — 01-07-2011 10:21 PM
Thread — Video on diagnosing no spark, low spark or intermitten spark condition on 1990's Cats Thread Starter — Blaine Forum — Arctic Cat: Powder Special and older Replies — 0 Last Post — 12-29-2009 09:56 PM
Thread — 2002 mxz 700 Thread Starter — snowpig28 Forum — Ski-Doo Replies — 2 Last Post — 02-05-2009 10:51 PM
Thread — 07 800 summit x 1996 670 mxz 2002 380f mxz Thread Starter — 2sled2day Forum — Ski-Doo (Swapmeet) Replies — 3 Last Post — 12-03-2008 07:01 PM
Thread — no spark 800 mxz 2001 Thread Starter — shawn Forum — Ski-Doo Replies — 3 Last Post — 02-19-2008 11:33 PM
