C
What is the hose that goes to each power valve for? I noticed today that one of the has a small tear in it, what effect would this have?
Hose goes to solenoid which is controlled by ECU. When ECU commands solenoid to close, cylinder pressure can now build on underside of bellows to overcome spring pressure and open exhaust valve.
any more reports back on this topic?
BIGGDAG have you changed the springs at all or are you just running the normal springs with the valves plugged then
hmm this is all interesting....wondering if i should try this...was just reading up on it on the IQ site, i am running an 05 900 and i ride flatland, maybe i should give this a try and see what this does with my sled
