I have a 2012 600 144 rmk and am wanting to stretch it to a 155. Has anyone ever done this? Any recommendation's or directions on what all to do? I know I would have to buy a 155 track and rails but...
Thanks
Thanks
Thanks
I have done this exact extension on the same sled. I can honestly tell you it made a huge difference on the sled with longer lugs and more flotation. I went with the tracks usa rail and tunnel extensions. Very impressed with both pieces and were just as strong if not stronger than one piece tunnel and rails due to their design and the way they are stiffened. I actually had to tow off my bumper with the tunnel extension kit on...was completely impressed even though it was just down a trail. You will need to make a few minor gearing and clutching changes for the longer track. Below is what I did which in my opinion was a perfect set up
- 155 x 2.4" Polaris Track
- Avid 2.86" Pitch Extrovert Drivers
- SLP Anti Stab Kit (Need to cut rails for extroverts)
- Tracks USA Rail Extension Kit
- Tracks USA Tunnel Extension kit
- 19 Tooth Top Chain case gear
- SLP BLue/Pink Primary Spring
The 19 tooth gear is what is in the stock 12 155 and the slp spring is higher engagement and higher rpm, which helps for track speed with the bigger track. I will see if I can track done some photos for you.
I would think about trading you a 14 800 155 RMK, located in South Dakota, save ya the hassle :face-icon-small-hap Pm if you have an interest.
Finally got my 2.86 pitch 155'' track and 2.86 pitch drivers. I think stock was 2.56 on my 144 600. Drivers and what not should all line up right? Rail extension kit comes in tomorrow.
