B
OK, now this really grinds my gears, decided to practice changing the belt in the garage so i'm not suprised in the field, like i've done a thousand times before. Unthreaded the bolt holding secondary on, removed washers, reversed the adjuster, threaded it back in, seperated the sheaves, just like the manual says, took off the belt no problem....
NOW, re-installed the belt, but started unthreading the bolt, and after only 1 revolution it was loose to the turn, i.e. the bolt is the only thing that backed out! The secondary stuck and is still compressed.
Frustrated, i re-threaded the bolt, hit it a bit with a rubber mallet to try jar it loose, unthreaded the bolt again, and still it was stuck in. With the bolt out, i still tried jarring it loose, nothing. Then I was just going to take off the secondary and see what the problem was, but noticed the sheaves came together again and the belt is tight between them, so unless i cut off my new belt the secondary's not coming off...
Justed called my dealer, told them the problem, they suggested me trailering it down, but I don't trust running it with it compressed. Maybe I'm wrong? Then they suggested threading the bolt back on the way it's supposed to be , lifting up the back and rotating the track to try and pop it back out. I wont have a chance to look at it til tomorrow.
Any suggestions? Should i try running it? Or just spin the track manually? This elementry $h!t better not happen on the side of the mountain or I'm in trouble:mad2:
