Where did all that oil come from?
27,380
So there I was.
Minding my own business.
Just wrapping up the last ride at the SnoWest Forum ride in Togwotee last weekend.
Pulling into the parking lot, not 20ft away from my trailer and suddenly there is a massive puddle of oil beneath my sled.
Pulled off the side panels and checked all the hoses and everything looked TIGHT and in place. Tank was BONE DRY and the oil came out hard and fast under pressure.
Putting her up on the lift in just a moment to start hunting for the cause.
B
BigFish BC
3,348
1,139
kitimat b.c
motor was running fine?did yah roll it over mabey the shut off valve failed.if it pushed it out you dont want to know:face-icon-small-sho.
27,380
Motor was running GREAT.
What ever came loose let go just 20 feet from the trailer in the parking lot under almost NO load at all.
It just BARFED all over the place in the course of a couple seconds.
Have the lift under the sled now.
Starting to take the oil tank off so I can see whats hidden behind it.
sidehil
687
158
Federal Way
Take the monkey and grab an 870 with some #6,s so you can't miss, then toss into the air in a safe place and dispatch the bugger! It's now off your back:face-icon-small-hap
P
ps
New member
Oct 24, 2010
13
2
3
check the return hose on the oil tank for a slit. I had one do it last month.
27,380
Ya, but this wasn't a leak. This hose exploded under pressure and dumped all the oil in just seconds. Makes me worry that there is a blockage downstream somewhere not letting throbbing return to the engine??
P
ps
New member
Oct 24, 2010
13
2
3
the hose is bad turn it inside out . I bet it is got a hole lot of cracks in it.
27,380
Replacing the hose is easy enough. What worries me is where the pressure came from to rip that apart. The return line should be a LOW PRESSURE line, shouldn't it!!
Sent from my iPad using Tapatalk 2 pro.
