Wheelie monster
So tighten the front shock down tight. Loosen the limiter straps. Then loosen the rear shock to soft. This should stand the front end right up? Right now it will barely lift the skies off from the snow.
Stand on the rear of the boards and pull on the handle bars and you may flip over backwards.
Skies are blue, skis are on your snowmobile.
[emoji16]
With a soft rear, it should lift the skis easily.
Sent it
I can stand on the back all I want and it will not pull the front up more than 6" off the snow. Everything is set at factory settings right now.
