I FINALLY did an oil delete and destroyed the oil sensor upon bottle removal (die you little piece of crap! die! die!). I pulled the sensor end out of the plug into the harness.
I'm about to do the same thing with the TSS. I'm taking the whole throttle block assembly off and making an index finger throttle, either with a mountain bike brake lever (or a snobunje lefty if I can find one for cheap). The thumb paddle just has too much swing to go from idle to WOT and I have to move my hand too much.
But my question is what's going to happen electrically with both of these sensors removed. I can handle an oil light staying on, but with the TSS removed it's not going to stay in 'tripped mode' is it? Do I need to put a resistor on it or something?
Thanks!
and if you've got a snobunje lever you don't want, I'll buy it!
Thanks!
