The voltage isIf be interested in this too. I have a bog i cant seem to get rid of. Where are you checking this?
Sent from my Pixel 3 using Tapatalk
Do you have a pinout or anything of what wires to check?The voltage is
Idle 1.12v ± 0.075v
Full open 4.416v ± 0.15v
CAUTION
Always disconnect the batter
y when performing resis-
tance tests to avoid da
maging the multimeter.
This is from the 20 service manual, another culprit maybe the mass air flow sensor as it is in the intake and maybe more vulnerable to moisture contamination.
Sorry for the terminology The TMAP sensorNo mass airflow sensor on these.
Red green is the source, black blue is the ground, and white green is the signal. A simpler check you can do is unplug the tps and put an ohm meter on the ground and signal run the throttle open and closed slowly and watch the meter it should be smooth and stable if it is erratic or jumps around you may need to go deeper. The voltage check does the same thing but better with more effort.Do you have a pinout or anything of what wires to check?
