studs, I've had great luck with wisecos in my 800 turbos, not a single issue.
I am not sure on the 800 r piston being 2 or 1 ring.
the ring from wiseco is less prone to deto flaking as its not chrome plated.
the forging wont break if you rattle it like a casting will, when testing an xp turbo system last season we got it to turn on the det light at 3 psi on 91 octane with a low compression head too boot !!!
faster than you could react to the det light the piston was missing a section of dome and ring land..
Now same sled, and set up, wisecos saw the det light and kept right on running. this was a test of piston durabilty and suitablity to a turbo for my flatland customers..
I won't send them out with cast pistons..but thats me on the flats with as poor a quality fuel as can be found. the mobil 91 is 14-22 % ethanol in winter in my area of southern NH . it fails isr test for every time..still has that nice epa sticker of 10% on the pump though,, makes you feel warm inside..
Gus
