WHAT DOES THE 850-Etec CRANKSHAFT ALONE ACTUALLY WEIGH ON A SCALE? (and an 800 Etec)
mountainhorse
I'm interested in seeing how much a new, production, 850-Etec crankshaft actually weighs on a scale...
Also the weight of the new flywheel, piston/wrist-pins...
For now... until we get an actual one on the scale...
What do the same parts weigh on on 800 Etec??
Got a 800-Etec crank to put on the scale John?
BRP, somewhere, is claiming a 2lb reduction in weight from the 800-Etec.
At least that will give us a 'ballpark' number.
I don't know the numbers but I was told by the BRP engine guy that the 850 crank gained weight over the 800 etec. All weight loss came from the mag and clutch, (possibly pistons and pins?) to end up at a net 2 lbs and change weight loss.
Ill weigh some parts and post up the info as soon as we have our new 850 sleds
The actual crank gaining weight does not surprise me... with the bolt on bob-weights and 80mm stroke/longer rods.... the mag and clutch weight drop... impressive so far.
I will try and remember to weigh an ETEC crank on Friday.
Dunno what the 850 crank weighs. No need to tear one open yet.....
I also thought it got heavier. Then add in the balance shaft and you have a whole lot of rotating mass added.
