You need to get rid of the plastic clutch cover shroud and put a prp/prp or green skidoo spring in the secondary. I would guess that the trask secondary helix is steeper. That coupled with the stock xm secondary spring will give you very little belt squeze in the secondary.
So you think I should try a stock Helix with green Skidoo spring? Or just change the spring that's in there now? Guess its really hard to say which side is slipping. Primary or Secondary. Everyone says to leave the shroud on cause its some special design. I think I should take it off as well.
