Using ZX stator in rev
Mar 15, 2009
23
1
3
The rev ski-doo computers uses ac voltage? For lightweight reasons i want to use a zx stator and zx volt reg and run a 05 rev harness and mpem. The rev stator has the 3 large wires (yellow, green) but also has a very small plug (green and black wires) coming off it that bypass's the volt reg and goes directly into the main harness. Is this the mpem ac power source? Wondering if that would be were i would put the voltage from the zx volt reg to?, to run the rev mpem, dpm, air temp sensor. Then i can also pull off that for hand warmers and headlight? if i chose to use those but would be nothing else at all.
