Twins for Axys 800
L
limeprormk
New member
Anyone know someone who makes twin pipes for an axys 800? Custom, or something?
I know terra Alps does, but I'm not sure I want to deal with them after hearing stories about their customer service.
You can use the 850 twins if you build flanges, some have modified their stock y-pipe into flanges.
Your talking Neil’s Power Pipes???
Here's my 2018 800 with flanges adapted to the outlaw 850 SLP pipes.
Work and tune done by Jadd at Stroker Customs.
Engine work done by Wade at T8RZ.
Don't know how many are out there but the sleds alot of fun and extremely responsive.
The cylinders are ported pretty aggressively from Wade. At the same time he bored the throttle bodies +2 mm. I believe he used an SLP head cover with MDS domes that he custom milled. I believe it's similar to a 14:1 compression ratio. Some of the intake box has been opened up a little.
The tune from Jadd is loaded through a Bullydog GT II. I have tunes for a single pipe and twins. They call it a Stage 5 and Stage 6 similar to SLP's staged kits.
Don't quote me on clutching. Ill have to look it up. If I remember right it's running a 140-320 primary spring, 68 gram SLP adjustable weights, a 56-46-.40 Helix, and a 155-222 secondary spring.
Sled runs on Pump 91 octane and I ride 6-9K
