Honestly, a $1500 turbo kit is asking for problems. Nobody sells a new kit for that, and a second hand kit will likely come with problems. If not, you are soooo lucky. Go big bore if you want a little more power. You can probably get 20 to 30 more hp depending on displacement increase. Turbo sleds are more expensive in the end everytime, and they have gremlins pop up more frequently because there is just more mechanical and electronic parts to them that can fail. Yes, a turbo can make more power ultimately, but they take more to build and maintain in every way.
To the point above, turbos are not really worth the coin and effort for a few pounds of boost. Do not put on a kit unless it has bigger injectors or secondaries with proper tuning. The tradeoff is not worth it just to hear turbo flutter with 5 psi or less. If you want over 200 hp, go turbo, but buy a full kit new so you have proper support. Otherwise, you will hate the experience.
