Turbo axys piston change interval
ez-ryder
Looking at a 16 turbo axys.
Tss/boost-it with a redline controller.
When should pistons be changed?
It has 1670 miles.
From what I seen on my friends stock pro I say 1500 miles on a non HO 800.
It has 1670 miles.
The old 800 that came in the Pro chassis is no comparison to the 800HO. Knock on wood, but I put 1,500 boosted miles on my 800HO last season, and a compression check at the end of the season showed good compression in #1 & #2
My 16 axys has a mtntk turbo with 1600 miles and both cylinders showed 110psi at 4500 ft which is excellent. I took the sled up to mtntk to have some work done on it and decided to do there fix it kit while it was there. It ended up being a good thing as both pistons had a lot of wear according to Sean at mtntk.
Thanks for the reply. What Sean found is the info I was looking for. Compression test on a two stroke motor is a lousy indicator for checking the condition of the pistons. It doesn't tell you what clearance they are at.
It needs disassembled and pistons measured.
Did he say what the clearance had increased to?
Nope just said they were not good at all. Originally Sean did not push me to do the kit either, I decided to do it on my own after reading to many horror stories. Some will go 4000 miles and others not much over 1000. Glad I decided to do it. Your right to, compression does not tell squat on piston shape.
Keep in mind that elevation also plays BIG in with compression readings-and doesn't do much for what your looking for.
I tore my16 turbo Axys down this summer with 2K boosted miles @ 7lbs just for grins....
There is not a magic mileage number any longer,and all my finding were in spec with respect to piston wear and zero scuffing.
After closer inspection, I discovered a nasty gouge in the wrist pin, so dodged a bullet there.
If your going to do it, (IMHO) do it right and send the mono block to Indy Spec and have the HG7 hone done to it.
I had them spec out the ring gap on the new pistons to the honed block,while it was there.
Unless you know the piston is damaged, or the compression is significantly different from one side to the other, I wouldn’t worry about it until at least 2,000 miles.
I installed the mtntk fix kit on my last two pros and they worked awesome. Not saying indy Dan's is not good because I know it is but mtntk makes a quality product.
I like the sound of this I used to run my turbo 1000 1500to 2000 miles on pistons I wonder what is common on the boondocker axys. Thanks
No experience with the boondocker but I had 1650 on my 16' silber axys with no problems. I got rid of it before doing a leak down but had no plans to do a top end before this year.
Looks to me that there is a lot of turbo axys. Still on stock pistons, anyone switching to aftermarket?
not me... stock has dun me right so when I slide a new set in it will be what came out because it worked! just don't need to "fix a problem" that's not their and don't want to save a few $$$ just to find out it wasn't worth it when my crank eats a piston skirt :(
So how many miles are you at ?
I went back together with 15 pro pistons/rings ...and had the ring end gap matched to the cylinder after the hone.
I remember a post by Ride Whistler a few weeks back about them inspecting the pistons/cylinders on a Silber boosted 800HO rental that had 4000 KM on it. Pistons/cylinder looked in excellent condition. Seems like the 800HO is a great motor to boost stock.
so I will start this year with 1548 miles 93 hrs. on a 16 axys, installed the sidekick at 1100 miles , going to see if it will run another year on original pistons
I have just about 1500 miles on my 17 with about 200 on a silber. Lost compression last year half way through the trip. Put new pistons and rings in as well as reeds.. I put about 20 miles on at home at 1000ft elevation afterwards. Hopefully it lives for 1500 miles. I'm kinda worried honestly ! Ha
