How much did you spend for a set of Zbros springs?
Been doing a lot of research lately and havent been doing much building on the sled other than installing some tunnel reinforcement plates from fastrax, and a new 64 series digitron gauge.
I pulled my old 1200 out of the prox and found an awesome home for the chassis as it will have a 1350 UBR WC triple and become a tar/asphalt sled and will be restored back to new and perfect condition.
Ive been doing some back and forth with crankshop, im sending them a motor plate to mock up pipes in a pro rmk we sourced at their shop so they can fit pipes.
I am seeing how much interest this could generate to build more plates and if crankshop can build fitted pipes for this application on a more regular basis for more people.
I will be shipping them a plate after thanksgiving and they told me 2 weeks out on building the pipes. I was going to fit them myself but Im trying to figure out if theres any interest for more people into building a big triple pro. If this winter the 1200 works out then ill do another with my 1500 cat in one come next season. I also have a buddy who we will be putting his cat 1000 twin big bore into one as well.
Should hopefully have a run of plates next week if anyone is interested in em to do a triple or big twin conversion in a pro rmk.
Im doing a big cat twin in one now and I made a design change to the original plate to accommodate the big cat twin (king cat zr upright engine), it wont affect anything else other than it will make it to where that specific case will now also bolt to it.
This plate will NOT work with any OEM CFI based engine cases (other than the billet PAR CFI based twins/triples) Basically anything with a flat bottom case.
put about 150 miles on it is all.
Getting it closer, its not dialed in 100%
It needed WAY more gear, finally got the rpm's where they needed to be, suspension still needs a bit of work, and definitely a track.
This summer im probably going to do full zbros shocks or a KMOD skid with raptors up front, camo extreme 156 3" cutdown paddle, finish the hood for it.
fun project, way fun sled to ride!
had some hang ups on getting more motor plates machined but got the first one done in my hand yesterday, just have to do a test fit in the chassis then machine the rest out. Doing 5 more total 3 of em are already spoken for.
