I have a 08 nytro mtx. Planning to put a challenger extreme on it and was wondering how tall luggs and length would slipp right inn.
And also what type of dimensions and theet i can put on whitout changing anything else?
Here's your options:
Without any changes/modifications at all:
Your looking for a 153" long, 15" wide, 2.5" tall lug, with a 3" pitch.
With a rail extension:
You can run a 162" (no tunnel extension required) or 174" long track(tunnel extension required), with the same dimensions as above.
With modifying/shaving rivets in the front of your tunnel and possibly drop brackets:
You can now run a 16" wide track. Length is based on the above options.
With modifying the front cooler (CR Racing has this service as well as others):
You can now run a 3" lug track. Length and width is based on the above options.
--If you want to run a track with a pitch other than 3", then you need to swap out your drivers to ones that match the pitch of the track you want to run.
Hope this helps,
-Justin
