Tied Secondary Lightening?
boondocker97
2,933
1,396
Billings MT
With lightening clutch components becoming popular (primary covers, Ti pins and bolts, primary and secondary machining, lighter secondary spiders, etc.) has anyone inquired or had a shop do any machining to lighten a Team/Venom Tied clutch? Either on the sheaves or the roller spider inside. When I swapped a 2018 primary and tied secondary to my 2014 the net weight gain was 1.6lb over the stock clutches. Would like to take some of that back off if it could be done reasonably.
sno*jet
2,159
678
I don't know about your clutch, but what do you know about the stock 17s? LOL (since nobody's answering your question..) I see ZRP and speedwerx have a few items. Think it'd be worth it to add them all? Ive had my doubts about titanium fasteners but Polaris guys use em a lot it seems.
boondocker97
2,933
1,396
Billings MT
The ZRP/Speedwerx lightened roller spider and the Speedwerx lightened helix are the only things I've seen advertised for those stock secondaries. Personally I'd spend the money on the more bang/buck items like the secondary spider, flywheel lightening, and recoil cup first and see if it makes a noticeable difference before cashing out for the TI pins and cover bolts. Pins and cover bolts are out at the outer edge of the clutch so maybe they make close to as much of a difference as one of the other parts? Maybe if I get ambitious I'll dust off my engineering mechanics book some night and see if I can make an on-paper argument for it. Higher grade Ti-6AL-4V is equivalent to about a grade 5 bolt and so is a 8.8 marked metric bolt. Replacing those gives me less heartburn than if you start replacing 10.9 fasteners.
sno*jet
2,159
678
ya, its the galling thing I guess I got hung up on with the cover bolts. use anti-seize or extra thread lock? I would think reducing weight toward the outer edge of the clutch would be good thing tho. especially if it was slightly out of balance. the weight has more leverage on the end of the crank the further out it gets right
boondocker97
2,933
1,396
Billings MT
Just saw that Speedwerx is now making billet aluminum spiders for the Team primaries. 0.75lb lighter than the stocker. No price yet.
sno*jet
2,159
678
well I sprang for the cover bolts since ill be in there changing weights soon. couldn't quite get there on the clutch pins. maybe im overthinking it.. was thinking the clutch was balanced with the pins installed. they use the stock steel nut on the ti pin so could affect the balance? Also, says made specific for Polaris, so wasn't sure if they'd be as good of fit on the team as the stock pins. If someone gets some, do report.
Not sure I want to dig into re-coil cup yet with my warranty still, and don't think lightening the flywheel would be good for holding rpm constant at WOT.
