  • I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
Thermostat Questions (2012 Silber Pro RMK)
Mar 2, 2011
95
11
8
Saskatchewan
Hi guys.
Just in the final stages of putting my 12' Silber Pro back together and was going to do the "$28 dollar" thermostat mod. I am interested to see if anyone else running a Turbo on their pro has done this. I could not get mine to fit without many hoses and parts rubbing together causing potential leaks.
Does anyone have any experience running no thermostat in a turbo pro? If so how is it for warming up and warming up after stopping for say 15 mins?
Does Polaris make a thermostat for the Pro RMK's that open earlier? ie say 110 Degrees F?
If anyone else has ideas to cool the sled down and keep it closer to that 115-125 degree range feel free to comment!
May 10, 2009
126
22
18
Calgary, AB
Polaris doesn't make a cooler thermostat option.
I have heard of guys with no thermostat, gutted thermostats and others that make different sized washers in place of the thermostat. Sometimes this takes a couple rides to get the hole size right in the washer to reach desired temps.
Mar 2, 2011
95
11
8
Saskatchewan
My concern with eliminating or gutting the thermostat is that won't the motor get a shot of ice cold coolant from the heat exchangers if there is no thermostat?
can anyone comment on their experience with running no thermostat?
Ie: Warm up time from a cold motor?
also how long do you have to wait to ride after stopping for 5-10 mins?
Also if anyone could chime in on the size of washer required to run no thermostat that would be great!
Octanee
1,015
131
Cranbrook Bc
I have no experience my self on the matter per say, though a mechanic by trade.... So the sleds have a thermostat for a reason and as do any engines, to not run one is asking for trouble, you have all that heat happening in the cylinders being produced, and greatly more under boost. If you have no t-stat the engine will run cold most the time, maybe very cold, I'd expect severe piston scuffing to occur as the pistons are hot and want to expand and the cylinders will be trying to squeeze in on them or even a cold seize. So I'd advise against taking the t-stat out and go with an alternative solution such as the xp t-stat or what ever other options are out there.
I believe the main complaint of the factory t-stat is it runs hotter than some may like and may cool off the engine too quick when hitting the powder/heat soaking after a pull?
I haven't had any issues my self, I let the sled idle after sitting for a period of time, say at lunch. idle for minutes, I then do a slow ride around an area to get everything up to temp/cooled coolant flowing. After a climb or some fun, itll idle again for a minute before shutting off...
