H
Is there a way to test the Voltage Regulator on my '12 Pro? Sled was acting up a couple weeks ago, cutting in and out when I hit the gas. Tried bypassing TSS, nothing. I got it home and now it won't run. To the point of no firing. Tested fuel pressure (58psi constant), checked for spark (has good spark), tested my stator (all within spec), then I checked the chassis grounds and they're good, disconnected everything to the bars to eliminate any pinched wires and nothing. I also tested the capacitor by putting 12v to it and see if it stored voltage. And it did, this time when I reconnected the capacitor the sled fired up for a second then died. Am I looking into voltage regulators? How do I test them to see if they're bad. Any input is appreciated. I also gave power to the ecm and I have no codes coming up.
