I rode my 2010 xf8sp out west last year and was very impressed, the 800H.O. motor still rocks at 9000+ plus, lightweight crank helps it spool up quick, not as much % power loss as other sleds i.mo.
I ran the 58gr weights (I think) which is what the chart called for, I was over-reving 8500-8600rpm, so I would try the next set heavier 6-9000ft. I think its 63g. I left the gearing stock 60/60, and I thought it was right where it should be, good belt life, never blew a single one! I forgot you are running a 2.25 track too, so maybe the 58gr wont over rev as much? If I were you, I'd copy the 9000'+ stock setup for the 2011 XF8SP w/factory installed 2.25 track.
I went everywhere I wanted too, or my abilities would let me, and that was with the 1.6 cobra! The 2.25 will be awesome! You gotta remember the xf141is the exact same sled as the m7 141 with more power basically (footprint wise). Lots of track speed and manuevarable. You'll have a blast.
I also ran a skinz superQ to lose 17lbs of weight, sled ran flawless! Stock 2010 skis aren't that bad either, in fact I was impressed & never felt the need to change them! I'd skip the powder pro's and save the $$$.
