spacehog21
What are the turbo guys using for 4 post primary STM clutch setups?
I have used a lot of setups on this clutch from mild to wild and was wondering what everyone has found to be the best balanced setup for mountians?
Last ride I used a 460 finish rate spring.
The supertips take quite a bit of weight in the heel to grab the belt down low on my setup.
If too much weight is in the middle of the arm then it takes more time to get to the topend.
Putting even four grams on the tips causes the arms to rotate backwards and stick in the clutch not allowing shiftout or engagement if there is not enough weight in the heel to overcome this shift.
Running light weights in the tip causes the belt to slip under max load.
I also tried 2 other 1200 turbo clutch setups that are working for others and they are not even close to what I am looking for.
Lots of different setups hold the power in the mid to high 7s for rpm but I am looking to bump it up to 8200 while keeping quick revs and operating at a very low engagement rpm as well.
My sled is a 1200 turbo but any STM 4 arm setup on a turbo sled would be useful information.
