forgot to ask...
What turbo kit, and fuel controller (or is it a re-flash?)
What sled is this on?
You may want to bump to 25% on the AV gas or race gas.
What altitude you riding?
12 Pro 800, Boondocker, newer box with built-in boost control, updated too newer tube air intake(box) with 2 injectors......RB motor when I did updates, runs great except the loose plugs and hitting Det on trail once and a while. Have EGT and O2 gauges, may see 1275-1325 on trail if I hold throttle in one position, mostly tree riding so mostly on/off type riding, not much hill banging. O2 seem normal 12.7-12.2 at full throttle, do see 16 at idle after a while after you start it. Ride 6-10k mostly.
I had my silber pump gas kit spit a plug completely out on my first ride out on the turbo running 91 octane non ethanol....Thought it was a pump gas kit?
What are you running for fuel? Are you running a timing key? What boost?
What boost and altitude? It is not pump gas at all boost levels and altitudes.
Internal or External Wastegate
What Elevation
5 pound spring at about 6500 feet when it happened. Maybe 6000. It was spring and temps were warmer. Should I mix a gallon or two of AV gas to play it safe?
No brainer here: detonation. Have your tune look at immediately.Every other ride on my turbo the spark plugs need to be tightened up, is this normal? New head and plugs. Is this just regular maintenance of a turbo?![]()
