K
Minus the shorter tunnel and different shocks - if one added the spindles, adjustable strap, smaller seat and expert bars.... would you kind of have an expert?
I only got 3 grand invested with the ace and the kinetic shocks and the regular raptors on the frontIf you did a complete Raptor swap
And could get back some cash from your take offs??
Would be a bit better than the Expert
1600.00 Ace skid
4000.00 shocks
1500.00? Track
100.00 Removable flap
80.00 durapro ski rubber
The new spindles do have a different geometry .. If you install a set you will see how towed out your skis are after the install , alignment has to be done , i had to bring each tierod out a 1/4 inch to get my alignment right again.. Geometry must be different , and they use the new ski rubbers .Pretty much, the riser is shorter 4.7” vs 6.5” and the boards are different as well. I’m in the camp of buying sp models as left overs from the previous season and adding suspension. And then adding bar,risers,and grips of my preference. The running boards are not a problem for me. The spindles are lighter on a expert but the same geometry. If you like to tinker an sp could work. If you want out of the box and ready to ride, Just get an expert then
And actually all 2021 Summits and Freeride use these new spindles.The new spindles do have a different geometry .. If you install a set you will see how towed out your skis are after the install , alignment has to be done , i had to bring each tierod out a 1/4 inch to get my alignment right again.. Geometry must be different , and they use the new ski rubbers .
I created an "expert" out of a 2018 154 SP.
Ice Age 165 rails and new 165 track. Z-bros T-motion lock out and Duropros. I already owned Fox Evol X shocks and the shorter 145mm riser.
I am into this sled and parts and all for about $5000 less than an expert. It has a warranty through the 2022 season.
2019 sp 154 $7500.00 needed track anyway
165 x 3" track and ice age rails 1700.00
KYB X shocks rebuilt $1000.00
Trimmed flap $0
lower riser $50.00
Total $10,250.00
Guessing thats $1000 for the revalved shocks... not the shock revalve, beings he started out with non rebuildable SP shocks.$1000 for shock rebuild/ revalve.
Wow.
Try GSR in Idaho next time.
Probably under $300 for all 4............
