SU27
Guys, quick question. 2010 D8, fix kit, no fuel commander, primary clutch serviced this summer - i.e. Weights, belt to sheave are correct, secondary aligned, belt is new. TPS adjusted correctly. Gasoline is fresh, 94 grade, no ethanol. Plugs are new BR9EIX (iridium)
Sled starts well (noticed decrease in idle RPM from 1700-1800 down to 1600-1700 though). Runs well up to 7000 rpm, and then check engine light comes on. Then it goes to retarded mode, and engine light blinks constantly. If i go to WOT from below 7000, engine runs ok - check engine comes up sometimes, but no retarded mode.
Unplugging ethanol wires helps a bit.
So, question: what should i take a look at?
Thanks,
Thanks,
