Ski Doo Parts For Sale Mostly Rev
Jan 10, 2008
64
7
8
59
Victor Idaho
SKI DOO PARTS FOR SALE
1.REV FIVE GALLON FUEL TANKS (2EA.) PART # 513033099
2.UPPER CROSS MEMBER PART # 518324739
3.2005 SUMMIT REV A-ARMS UPPER AND LOWER BOTH NEW TAKEOFFS AND USED
4.2005 SUMMIT REV TIE RODS
5.A-ARM BALL JOINTS BOTH UPPER AND LOWER
6.2005 SUMMIT REV SKIS SIDEHILLER NEW TAKE-OFFS
7.2004 MXZ PRECISION SKIS USED WITH STUDBOY SHAPER BARS
8.2006 800 HO NEW CYLINDERS WITH STARTING LINE PRODUCTS PORTING ( 2 EACH)
9.800 FACTORY MOD CHEATER HEAD SET FOR 110 OCTANE
10. FACTORY MOD LIGHTWEIGHT RACE TANK SETUP ( TANK, MOUNTING BRACKETS, CAP, FILLER NECK, CONNECTING HOSE, SIDE CURTAINS, HOOK & LOOP TAPE FOR ATTACHING CURTAINS)
11. LIKE NEW CRANKSHOP RV 990 BIG BREATHER BOTTOM END ( 150 MILES ON NEW CASES, CRANKSHAFT, PISTONS AND RINGS) WITH USED ROTARY VALVE, RV COVER, 48 MM CARBS, REWIND STARTER, STATOR, FLYWHEEL, PICKUP, IGNITION COIL, CDI BOX AND WATER PUMP
12. CRANKSHOP 990 REV TWIN PIPES (LIKE NEW)
13. REV SPORTECH COBRA WINDSHIELD ( MID HEIGHT, BLACK WITH MOUNTING HARDWARE)
15. NEW 2006 REV X MODEL HANDLE BARS
16. SUMMIT REV X HANDLE BAR HOOKS
17. BRAND NEW 2005 VSA 27 SECONDARY CLUTCH (NON ROLLER) WITH 47/44 DEGREE HELIX (2005 SUMMIT REV 600)
18. NEW HEELCLICKER CLUTCH KIT STSTRA3 45-10 REV 600 WITH GREEN, PURPLE & BLUE SPRINGS, ALL HARDWARE & PAPERWORK
19. NEW HEELCLICKER CLUTCH KIT STS1TRA3 73-12 REV & SUMMIT 800 WITH GREEN, PURPLE & BLUE SPRINGS, ALL HARDWARE & PAPERWORK
20. NEW HC- X RIGID SECONDARY CLUTCH SYSTEM FOR A 800 HO SUMMIT REV X WITH A 46 & 50 DEGREE HELIX, YELLOW & RED SPRINGS AND PAPERWORK
21. HPG REAR SUSPENSION REAR TAKE APART SHOCK WITH REMOTE AND COMPRESSION ADJUSTABLE (FITS ALL SUMMIT REVS THRU 2007)
22. HPG REAR SUSPENSION REAR TAKE APART SHOCK 2008 REV XP X WITH HILLCLIMB VALVING
23. SET OF 10 TOOTH I/O DRIVERS 2005 SUMMIT REV X 144 ( USED BUT IN GOOD SHAPE)
24. 2005 SUMMIT REV X 144 COMPLETE CHASSIS THIS MACHINE IS ALL BLACK AND IN EXCEPIONAL SHAPE, ALWAYS GARAGE KEPT AND VERY CLEAN ( IT HAS APPROX. 400 MILES) HAS ALL X MODEL PARTS LIKE WAVE BRAKE ROTOR, HANDLEBAR RISER, CLEAR GAS TANK, 10 TOOTH DRIVERS, ONE PIECE SPEEDO/ TACH GAUGE. ALSO INCLUDES THE FOLLOWING:
1.MXZX 440 RACING FRONT END: CHROMOLLY A-ARMS (LIGHT BUT STRONG) WIDE FRONT STANCE CENTER TO CENTER 43"
2. SKI SHOCKS: ELKA RACING REMOTE RESERVOIR WITH ADJUSTABLE COMPRESSION AND REBOUND. HYPER COIL DUAL RATE SPRINGS
3.HOLZ COMPETITION COILOVER REAR SUSPENSION WITH TRANSFER ADJUSTABLE REAR AIR SHOCK (3 SHOCKS IN ALL: CENTER = FOX ZERO PRO COILOVER DUAL RATE SPRINGS REAR= FOX ZERO PRO WITH REMOTE RESERVOIR & COMPRESSION ADJUST AND COILOVER DUAL RATE SPRINGS AND A FOX FLOAT R TRANSFER SHOCK
4.ALL WHEELS ARE PROLINE ALUMINUM WITH 8.5" BIG WHEELS ON REAR AXLE
5. RAIL REINFORCMENT KIT
6.FRONT END BRACING
7.SPORTECH WINDSHIELD
8.TEAM HYVO CHAIN AND GEARS
9.10 TOOTH I/O DRIVERS
10. BRP REAR FOOTREST KIT
11. RUNNING BOARD REINFORCING KIT
12. ROETIN RUNNING BOARD TRACTION SCREWS
13. STARTING LINE PRODUCTS, BLACK STRAIGHT LINE TRACKER SKI'S WITH BLACK COMPETION SADDLES AND 10 INCH 60 DEGREE SNOCROSS COMPETITION CARBIDES WITH RED LOOPS
14. STARTING LINE PRODUCTS, FLOW RITE FILTERS INSTALLED IN INSTRUMENT POD
PLEASE CALL ME AT 307-413-4807 WITH ANY QUESTIONS (EVEN IF YOU SEND ME A PM) OR PRICES AND FEEL FREE TO MAKE OFFERS ( I TRY TO SELL STUFF FOR 50% OF RETAIL PLUS SHIPPING)
IF YOU WOULD LIKE ANY PICTURES SENT TO YOU PLEASE HAVE YOUR EMAIL ADDRESS
THANKS BOB
