Ski-Doo Multi Purpose Electronic Module
ridealaska
Mar 9, 2009
177
33
907
Im having problems with my tach and headlights. The wiring looks ok so i was wondering if maybe the MPEM was the source of the problem. The problem is my headlights and tach don't turn on when i start the engine. Any help would be appreciated!
evandaigneault
552
42
Portland,OR
Did you check the connections? I dont think it would be the MPEM, but you could always pop off the connection and see if any pins are bent. It is probably just a loose connection or a problem with the voltage regulator maybe
nor-cal
40
northern ca.
I thinks peeps has it. On my 07 the relay sits just inside the left cover and hanging above the airbox. I had the same problem couple years ago I would unplug it bring it inside over night and the sled would have no symptoms. leave it out all night and no tack or lights in the morning. I would say that you most likely have the same problem.
spike
New member
Dec 23, 2007
7
Had the same issue on my '06 summit.
The relay is about $5 at NAPA or Canadian Tire.
Sometimes a rap on the relay will smarten it up for a short while.
