Ski-Doo 850 handlebar replacement recommendation request
Ranzou
My left handlebar got bent about an inch forward yesterday while rolling out of a creek bottom. While its still usable, it feels funny. I'm going to try to bend it back.
Any recommendations for a replacement handlebar setup?
No advise on a replacement but do not bend it back it will weaken it quite a bit. Just ride it now until you get your replacement.
x3 on the CFR bars. Note if you go this route, you will need to buy xm "X" model riser, bar clamps, and mountain strap (if you want to run the mountain strap). I also did some creative cutting with an exacto knife to run the CFR bar pad along with the mountain strap. I was quite surprised that BRP did away with the bar pad this year.
I have a stock bar with cork on the bars I would sell ya. Have my old stock grips also.
Not interested but what does with cork mean?
From the factory the bars come with a thin wrap of cork on the bars for insulation purposes. Under your grips are aluminum bar, then a cork wrap, heater and the grips over the top.
After doing some research, I believe that I will pull the trigger and jump into the CFR Boondocker 2.0 bars and add a short adjustable riser block.. We have alot of rocks here in northeastern Nevada and I'd only like to replace the bars once if possible (fingers crossed).
I am 5'8" and i have a total of 6" rise with risers and bar rise put together and love it over stock, way more control and more resonsive! https://www.instagram.com/p/BOqty5sD6AJ/
