  • I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
Silber turbo, things to watch for
kmg
New member
48
4
8
Just put a silber on my 2.6 163 New to turbo sleds. Anything out of the ordinary to watch for or anything you've done before riding? I plan on putting reflective tinfoil tape on my side panel and maybe underside of the hood directly above.. anything you've done at all to improve your overall experience I wanna hear it!!
Thanks
tuneman
929
843
93
Minnesota
www.everettsports.net
- Their clutching is pretty lame. Go with an Indy or TRS setup, or at least get a 44 or 46 degree straight cut helix. Your belts will thank you.
- Pull all the foam out.
- Heat tape the coolant line by the muffler.
- Fully clip your track.
- Add venting or a blow hole. There isn't enough cooling for heavy snow.
- Buy -eya plugs and gap them at .018"-.020".
- Coat your exhaust donuts with a thin layer of of high temp copper gasket maker.
xpspenziv
2,883
773
hanging out in a tree well at the top.
Get ahold of TRS Tony in here.
1. His lightning weights.
2. 46f-32f er helix
3. Green 140-290 primary spring
4. Black /silver 160-280 Secondary. @ #7
This s a proven set up. Depending on elevation and boost you may be able to go softer on the secondary spring. This is an arm stretcher @3000-6000'
5. Anti stab kit.
6. Avid extrovert drivers.
deschutes
729
264
Agree with most of this, except EYA plugs. We just could not get them to work as well as the standards. Never had an issue with plugs otherwise.
willjogervais
434
250
SW Minnesota
Odd, they made a world of difference in my 800ho over the bpr9es. It's amazing how different things work (or don't) for different people. Just goes to show it doesn't hurt to try different things :juggle:
kmg
New member
48
4
8
So what heat plug should I be using? Right now I have BR8s in.
Also with the exhaust wrap around the coolant hose.. being im buying some and will have it is it stupid to wrap the down pipe and can to try and drop under hood heat a bit? Or would that be a waste?
Also this was a last minute deal.. I wasn't going to do this for this year.. long story short I leave friday.. how bad will I eat belts or hate life with the silber clutching?
papafinger1
11,012
527
minnesota
Could order the clutching and have it sent to where u are staying. Ride it with the provided set-up the first day and if u don’t like it switch it out that night over a few beers. I’ve done similar and it has always worked out great. Just give the place a heads up to expect a package for you.
deschutes
729
264
Ya, there is definitely not a one size fits all, especially when you start boosting. I know when we talked about this same plug a couple of years ago I was in the minority as well. We may have the right altitude, mix of AV gas, turbo pressure, temps, etc. that works well with the BPR9ES. The stock plug runs great - no popping and can't remember ever fouling one. We have fouled more 850 stockers than all our turbo builds combined. : )
Jul 22, 2009
499
76
Make sure your power valves are clean. I developed an after-boost big that turned out to be dirty power valves. I went with Indy clutching and have been happy with it. Overall the Silber kit has been very good to me. 2nd year turbo’d now on a 16axya.
willjogervais
434
250
SW Minnesota
You will be just fine running Silber's clutching. The weights are adjustable with magnets. At least they were, I haven't opened the box yet for my 850. You should be able to get it dialed in good enough where it will be a riot to ride, then you can decide if you need to spend the money on a different clutch kit.
xpspenziv
2,883
773
BPR9 EYS is a colder plug. NGK plugs temp ranges are lower the #, the hotter the plug. The plugs will tell you if you need a hotter or colder plug. Look for the burn mark (rainbow )on the ground strap. You want it at the bottom of bend or a little lower. For proper a/f ratio get a magnifying glass and a bright light and look at the base of the porcelain. There will be a burn ring. If you have black specks on the porcelain that is pre ignition.
alstar
99
31
18
North of Duluth, MN
Have a Silber on a 16 axys sks and it keeps blowing the spark plugs (seems to be always on the exhaust side). The porcelain is actually breaking free and moves up and down inside the outer ring. Anyone experience this issue and have any thoughts/suggestions on what the issue may be?
o2bncamo
163
41
wisconsin
That is detonation, you need to get that under control before it gets expensive.
Add octane or fuel, turn boost down, lower compression. Sometimes over rev can cause detonation too.
Oct 8, 2010
8
A lot of my slower NA friends where cracking their NGK plugs last winter. We figured it was a bad production run.
If o2bncamo is right, detonation can be very expensive. If it is detonation you need to get it fixed quick.
I add 10% race gas as cheap insurance.
I did have detonation once after I started adding race gas . It was at the start of a day when I would get into the throttle. It cleared up after a while and I the rest of the day it was fine.
AKFULLTHROTTLE
1,971
1,117
Alaska
Should be running 9s. I stick with the standard plug gaped to a tight .018. Clutching depends on your elevation.
