2017 F-450 Platinum Ultimate. Bought it used just over a year ago with 113K miles on it. Has 125K now.
Things it has I would definitely get on another truck:
-Heated/cooled seats
-Heated steering wheel
-LED headlights
-Sync system
-360 cameras
-Power fold running boards. They drop down lower than solid boards and don't get ice built up on them.
-Power extend and fold mirrors.
-LED box lights
-Factory installed gooseneck hitch
-Tailgate step. Used to think this was a gimmick until I got a truck with one. These new superduty trucks are so tall I use it every time I'm getting in and out of the bed.
Things I could live without on the next truck:
-Sunroof. Take up headroom in the cab, they break if you don't use them frequently, and they are expensive to fix.
-Adaptive cruise control. Slows you down when behind another vehicle and sometimes you don't notice. Limits bumper, grill guard, and aftermarket lighting choices.
-Auto-dim headlights
-Auto wipers
-Massaging seats. They are kind of nice when you've been in the truck for a few hours on end, but not life changing.
-FX4 package. Shocks are not a big improvement, haven't used hill decent control, and you don't get the locking differential in the F-450 with the package. Skid plates can be added separately on the build for just over $100.
Things I've replaced/upgraded:
-Added AVS low profile side window visors (not pictured).
-Husky X-act floor mats
-Fox 2.0 shocks
-Added Rigid light bar
-Replaced rear transfer case seal
-Replaced broken headlight housing (was cracked when I bought it)
-Replaced plastic cover on tailgate step
-Replaced intake temp sensor.
Things I love:
-Power
-Stability empty or towing. The wind doesn't push a truck like this around.
-Sharp turning radius of the wide track front end.
-Braking performance
-Overall look of the truck
-How quiet the cab is.
Things that need improvement:
-Parts are expensive. Headlight housing and balast is $1800 MSRP and the plastic cover kit for the tailgate step was $190. New gooseneck ball is a couple hundred bucks.
-Gooseneck ball release mechanism. Mine is stuck and I cant get the factory ball out without destroying it.
-This thing should be available with more rear end gear options than just 4:30s. It takes a good grade to even make it shift down from 6th to 5th towing a trailer and it would improve the poor empty mileage. The 2020+ trucks with the 10 speed automatics are reportedly better though with the extra overdrive gears.
