Having issue with my adjustment screw backing out on my secondary clutch after I adjust it and crank on the locking nut. anyone have issue with that and can it be solved with pulling it out and adding a little loctite?
I had the same problem om two different Axys 800. The most simple fix is to back it out about 1/4" put blue locktite on it readjust and let it set. You don't have to re-locktite every time you reset your deflection, it seems to work for a dozen or so adjustments.
