Rough idling 2020experts
skank
438
84
Mountain View, Wyoming 82939
Anybody else experiencing rough idling 2020’s? The two experts I have ridden have an obvious rough idle and even quit occasionally. It’s very different from the 17-19’s. Thought about pulling plugs and checking the indexing. Anybody else??
kcj1317
325
75
Edmonds Washington, St Charles Idaho
When I first start it if I don't rev it a little in the beginning it will die.
Sent from my SM-G930VL using Tapatalk
sledhead_24_7
2,289
700
Jackson Wy
Mine idles rough as well. It idles good then misses for a sec, RPM drops to 8 or 900 real quite then back up to 1200. Has quite once. Put new plugs in no real change.
hamlin
446
161
We rented a 2020 summit sp in wolf creek two weeks ago, when we started it to load it up, it died couple times. Throughout the day I thought it idled rough and too low dipping below 1000 a lot. It quit once but after that I kind of feathered it a little if I idled. My point being I don’t think it’s isolated to experts
yamiman
39
ND
I just changed my head out on my expert and both plugs were not indexed correctly to the injectors. Prior to this my sled idled like crap. With new plugs correctly indexed my sled runs and idles perfect
tinkerjohnson
1,133
242
Southern utah
Ok I guess I'm checking my plugs
Sent from my SM-S327VL using Tapatalk
tinkerjohnson
1,133
242
Southern utah
I just went and pulled my plugs, sure enough they were exactly wrong on both cylinders blocking the injector. Reset them in the acceptable range and my idle seems to be steady at 1200 now, it never dropped to 800 like it would do before. I would say if you have a rough idle I would check this out
Diamond8
367
99
Tri-Cities Washington
My 2020 has had a rough idle as well.......worse once warm and up on the hill.....hasn’t died yet while idling but idles low and rough with a miss every now and then......but otherwise it pulls hard and is running like a champ.....just a rough idle once warm. Nice to hear I am not the only one.......oh and my sled is 175 Summit-X
skank
438
84
Well guys I just confirmed that it’s the spark plugs not being torqued and indexed causing these issues. Mine were 180 degrees out and were not torqued down at all. I marked them and reinstalled them with proper torque and they were spot on. Idle is smooth now and proper rpm. It doesn’t stumble and die any more and it also doesn’t die going into reverse anymore. Probably worth a hp or two even on the top end
I bet! Check your plugs folks! Or have your dealer take care of it. 👍
High Voltage
1,057
354
83
Helena, MT
Mine idles ok but will make a weird low tone blurp,blurp,blurp, and then back to normal idle. It does this right after you work it a bit then come to a stop.
