I know most people are not watching snowest threads but hopefully some of the die hards are still check for new posts. This will be long so bare with me. So I have a buddies 2016 Axys with a boondocker turbo. Last year it broke the engine mounts and destroyed the case and the Voltage regulator when the belt blew. It is all back together and on the first ride in December it only made it about 1 mile down the trail. It over heated and died and could never get it started again. The dealer has had it for 4 months and could not solve it. They installed a new stator but still would not start. He brought it to me to see what I could find. I got it back and first unhooked the boondocker box and it fired right up. Stopped and started a few times and it was all good. Sent the box to boondocker and they said it was bad. Awesome I thought I had it fixed for sure. But wait got the new box back and it’s the updated Auto adjust. Plugged it in and it fired right up. Started and stopped it a bunch of times and got it up to temp after about 10 minutes of running, it won’t start crap! I have checked fuels system has around 60 psi. Checked spark it has spark but seems weak. Reset the TPS all good but idle is too low at the 940 spec. When I can get it running it’s so low it will die. Checked the Voltage regulator as per the manual and it seems good. Check the stator ohms it does not match the book specs they are all higher ohms then the book says, but no shorts or grounds. I have narrowed it down to a fuel issue. If I unhook all the harnesses and let it sit for a few days then plug it all back in it will start but once it gets hot it won’t restart. If I use a shot of starting fluid it will start and run but once you shut it off it won’t restart. So for some reason the injectors are not firing. Anyone got any ideas? Could it be injectors or is my stator not producing enough power. Can you test the stator output when cranking?
